AAA Session Context Error
Dec 8th, 2008
Dear Experts,
We are using Cisco 7301 as our NAS for our DSL users and a third party software as Radius
We configured PoD radius server for our DSL . But it seems that radius can't remove the users from the NAS .
The following is the error
Dec 7 20:33:27.547: POD: Added Reply Message: No Matching Session
Dec 7 20:33:27.547: POD: Added NACK Error Cause: Session Context Not Found
The following is my config
aaa server radius dynamic-author
client <radius ip address>
server-key cisco
auth-type any
ignore session-key
ignore server-key
aaa pod server auth-type any server-key cisco
1 vote
wdrootz Fri, 12/12/2008 - 14:37
The work around, to avoid this failure, is "aaa session-id common" needs to be enabled.
Haris P Sun, 12/14/2008 - 00:28
My Issue is fixed now
The "aaa session-id common" command was enabled already . But my Issue was different
I got two interfaces from NAS going to two different switches and both were seeing as two different NAS by radius . So sometimes the radius request go from one interface and comes from another interface and it was conflicting the session .
As per Cisco , For a call to be disconnected, all parameters must match their expected values at the gateway. If the parameters do not match, the gateway discards the packet of disconnect packet and sends a NACK (negative acknowledgement message) to the agent
novanetinc Mon, 06/09/2014 - 07:26
Add below mentioned commands under aaa config of cisco router
ignore session-key
ignore server-key
post it freeradius will start disconnection active sessions on cisco NAS.
Freeradius config.NAS IP(
# echo "Acct-Session-Id=D91FE8E51802097" > packet.txt
# echo "User-Name=somebody" >> packet.txt
# echo "NAS-IP-Address=" >> packet.txt
# cat packet.txt | radclient -x disconnect ''secret''
Sending Disconnect-Request of id 214 to port 3799
      Acct-Session-Id = "D91FE8E51802097"
      User-Name = "somebody"
      NAS-IP-Address =
rad_recv: Disconnect-ACK packet from host port 3799, id=214, length=20
