Name Ports
Answered Question
Dec 8th, 2008
Hi. You can help me with name port's on WS-C4900M. In 1 slot install WS-X4908-10GE
, in 2 slot install WS-X4920-GB-RJ45, In 10GB slot install X2-10GB-LRM=.
You can tell what will be name port's. (for example on WS-C3750E-24TD-E 1-ports gi1/0/1 24-ports gi1/0/24)
Correct Answer by mihanlin about 8 years 5 months ago
On the 4900M, the port numbering is as follows:
interfacetype bay/port
So if you have a 4920-GB-RJ45 in bay 1, it will be:
GigabitEthernet1/1-20
If you have a 10Gig card in slot 1, then it would be:
TengigabitEthernet1/1-8
Michael
Overall Rating: 5 (1 ratings)
Correct Answer
mihanlin Mon, 12/08/2008 - 01:50
  • Silver, 250 points or more
Michael
