only config backups
Dec 8th, 2008
What might be best way of collecting config backups only. Is there any tool for that which do same thing that RME "config backup" Every time when configuring switch/router RME collects changed config. Is there any other tool which do same or do i have to buy LMS bundle and only RME for that. Is that possible anyway.
any idea
Overall Rating: 4.8 (3 ratings)
Danilo Dy Thu, 12/11/2008 - 03:42
Use the IOS "archive" feature.
Step 1
Setup an FTP server
Step 2
In the FTP server, setup a directory structure (recommended if you have multiple routers/switches and you want to secure the directory from other users)
Step 3
Create a user account in the FTP server with write permission. i.e.
Login ID: cisco-user
Login Password: cisco-password
Step 4
Configure Cisco Router
Router_Name(config)#ip ftp username cisco-user
Router_Name(config)#ip ftp password cisco-password
Router_Name(config-archive)#path ftp://ftp_server_ip_address/directory_level1/directory_level2/Router_Name
Router_Name#wr mem
Everytime you save the router configuration, it will send a backup to the FTP server with a suffix of -1, -2, -3, and so on….i.e.
You can also use SCP or SSH. But for sanity, start with FTP first to see how it works.
WARNING: If you opt to use server side scripting, be very careful where you put the script and who has access to it as the username and password are usually in the script.
