How to activate 802.11b on 1242AG
Dec 8th, 2008
How do i activate 802.11b? My 802.11g is working fine but we have a handheld which is 802.11b. I can only see 802.11g and 802.11a from my access point.
thanks!
Rob Huffman Mon, 12/08/2008 - 05:35
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Eduard,
Are you running any 11b supported data rates like 1,2.0, 5.5, 6.0, 9.0 or 11.0
Note: The client must support the basic rate that you select or it cannot associate to the wireless device. If you select 12 Mbps or higher for the basic data rate on the 802.11g radio, 802.11b client devices cannot associate to the wireless device's 802.11g radio.
Just a thought,
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
