DNS problem with WLC2206
Dec 8th, 2008
I've setup a WLC 2206 with 3 LAPs. They register fine and all seem to work. The APs are directly connected to the internal switch of the WLC (P6, P7 and P8). I do not use VLANs. P1 is the connection to the rest of the network.
I can manage the WLC. The WLC sees the LAPs, and they register.
When a client connects, it works as expected. I see the association in the WLC.
HOWEVER: when the client tries to surf the web, the 'site cannot be found or DNS error' occurs. I use WebVPN, so I would expect a redirect to the login page. The DNS resolving however, does not work, and this error occurs.
When I type in the browser: https://1.1.1.1
I do get the login screen, and I can login.
The IP settings appear to be right (correct IP/mask/gateway/DNS) but resolving is an issue.
Can anyone help?
Marcel
Scott Fella Tue, 12/09/2008 - 18:00
With WebAuth, the clients homepage or URL they try to first go to, can't be a secure site (https). Have you tried to see if Google for a home page works.
