DMZ setup
Dec 8th, 2008
Hello everyone,
I have a small problem I am hoping someone can offer some assistance with.
I have set up a test network using a pix 515e, and a 3750g switch. I have 1 interface on the pix in the 10.10.1.1 network, which is my internal lan. I have another interface on the pix with IP address 10.10.2.1, which is my DMZ network.
Both interfaces patch into the 3750g, the internal pix interface into port 1/0/1, and the DMZ interface into 1/0/15. Vlan 1 on the switch has IP address 10.10.1.250.
I also have 2 servers in vlan99 (dmz vlan) on the switch, which 1/0/15 is also a member of. Vlan 99 has IP address 10.10.2.250. The 2 servers have a default gateway of 10.10.2.1 (dmz interface on the pix). These 2 servers cannot ping the default gateway, but I can ping the servers from the switch.
There is only 1 route on the switch which is the default route to 10.10.1.1.
Does anyone know why I cannot reach the DMZ interface on the pix from the switch? ICMP is allowed on the pix interface.
Any assistance would be greatly appreciated.
n
Jon Marshall Mon, 12/08/2008 - 03:10
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
How have you allowed ICMP on the pix interface ?
Do the servers only have one NIC ?
Are your subnet masks consistent.
What version of pix software are you running ?
The pix DMZ interface and the server ports are all allocated into vlan 99 and this exists as a L2 vlan on the 3750g ?
Jon
Gatling_uk Mon, 12/08/2008 - 03:16
Thanks for the quick reply.
Pix version 7.2
ICMP permit any any inbound on the pix dmz interface (just for testing).
Subnet masks are all consistent.
Only 1 NIC per server, patched directly into the switch.
Sorry, the dmz interface on the pix is unallocated , it is in the default vlan. The 2 servers are both in vlan 99 and I have now removed the IP address allocation from that vlan. Was just tinkering with it earlier.
Thanks again.
Jon Marshall Mon, 12/08/2008 - 03:23
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Christopher
Just to clarify then
1) you have "icmp permit any " in your configuration
2) Not sure what you mean by "The 2 servers are both in vlan 99 and I have now removed the IP address allocation from that vlan"
Jon
Gatling_uk Mon, 12/08/2008 - 03:28
1) that's correct, but no traffic reaches the dmz interface on the pix from the switch, it is not strictly icmp traffic that is the problem.
2) Both servers are patched into vlan 99 on the switch, but that vlan no longer has an ip address. (I added the ip address this morning whilst testing but have now removed it).
Gatling_uk Mon, 12/08/2008 - 03:29
Further info:
The switch does know that the pix interface is there, it's mac address appears in the switch cam table.
Anything else just ask :)
Jon Marshall Mon, 12/08/2008 - 03:34
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
"Anything else just ask :)"
Well since you asked :-)
Can you post output of
"sh vlan"
"sh run"
from the 3750
"sh run" from the pix.
When you try to ping the DMZ interface from a server what do the arp tables look like on
i) the server - is the DMZ mac-address there ?
ii) the pix - is the server mac-address there ?
Jon
Gatling_uk Mon, 12/08/2008 - 03:45
#sh run
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname switch2
enable secret 5 $1$rMLz$axMm2ss8kb3bnq001Ok3f1
no aaa new-model
switch 1 provision ws-c3750g-48ts
system mtu routing 1500
vtp mode transparent
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan access-map 99 10
action forward
vlan internal allocation policy ascending
vlan 5
name vMotion
vlan 29
name Colo Network
vlan 77
name Management
vlan 99
name DMZ
interface GigabitEthernet1/0/1
switchport mode trunk
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
switchport access vlan 77
switchport mode access
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
switchport access vlan 5
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
switchport access vlan 29
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
switchport access vlan 99
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
interface Vlan1
ip address 10.10.1.250 255.255.255.0
interface Vlan5
no ip address
interface Vlan77
no ip address
interface Vlan99
no ip address
ip default-gateway 10.10.1.1
ip classless
no ip http server
control-plane
Gatling_uk Mon, 12/08/2008 - 03:46
VLAN Name Status Ports
1 default active Gi1/0/2, Gi1/0/3, Gi1/0/4
Gi1/0/5, Gi1/0/6, Gi1/0/7
Gi1/0/8, Gi1/0/9, Gi1/0/10
Gi1/0/11, Gi1/0/12, Gi1/0/13
Gi1/0/14, Gi1/0/15, Gi1/0/16
Gi1/0/33, Gi1/0/34, Gi1/0/35
Gi1/0/36, Gi1/0/37, Gi1/0/38
Gi1/0/42, Gi1/0/47, Gi1/0/48
Gi1/0/49, Gi1/0/50, Gi1/0/51
Gi1/0/52
5 vMotion active Gi1/0/28, Gi1/0/29, Gi1/0/30
Gi1/0/31, Gi1/0/32
29 Colo Network active Gi1/0/39, Gi1/0/40, Gi1/0/41
77 Management active Gi1/0/17, Gi1/0/18, Gi1/0/19
Gi1/0/20, Gi1/0/21, Gi1/0/22
Gi1/0/23, Gi1/0/24, Gi1/0/25
Gi1/0/26, Gi1/0/27
99 DMZ active Gi1/0/43, Gi1/0/44, Gi1/0/45
Gi1/0/46
1002 fddi-default act/unsup
1003 token-ring-default act/unsup
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
Jon Marshall Mon, 12/08/2008 - 03:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Christopher
Your'e original post said that the DMZ interface was connected into the 3750 on interface 1/0/15. Have you changed this to be one of the 43/44/45 interfaces ?
Also can you remove the vlan access map config from your 3750 for vlan 99.
Jon
Gatling_uk Mon, 12/08/2008 - 03:56
Sorry yes, it is now the 43 interface.
I have removed the vlan access-map.
Gatling_uk Mon, 12/08/2008 - 03:51
Modified pix output:
hostname
domain-name
names
dns-guard
interface GigabitEthernet0/0
nameif outside
security-level 0
ip address
interface GigabitEthernet0/1
nameif inside
security-level 100
ip address 10.10.1.1 255.255.255.0 standby 10.10.1.2
interface GigabitEthernet0/2
nameif dmz
security-level 90
ip address 10.10.2.1 255.255.255.0 standby 10.10.2.2
interface GigabitEthernet0/3
description LAN/STATE Failover Interface
interface Management0/0
nameif management
security-level 100
ip address
management-only
ftp mode passive
clock timezone GMT/BST 0
clock summer-time GMT/BDT recurring last Sun Mar 1:00 last Sun Oct 2:00
dns server-group DefaultDNS
access-list acl_dmz extended permit icmp any any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
mtu management 1500
failover
failover lan unit secondary
failover lan interface state GigabitEthernet0/3
failover key *****
failover link state GigabitEthernet0/3
failover interface ip state 172.17.1.1 255.255.255.252 standby 172.17.1.2
icmp unreachable rate-limit 1 burst-size 1
icmp permit any outside
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat (inside) 0 access-list nonat
access-group acl_outside in interface outside
access-group acl_dmz in interface dmz
route outside 0.0.0.0 0.0.0.0 172.29.1.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
sysopt noproxyarp outside
sysopt noproxyarp inside
sysopt noproxyarp dmz
sysopt noproxyarp management
service resetoutside
prompt hostname context
: end
Jon Marshall Mon, 12/08/2008 - 04:04
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Christopher
Can you add to your config
"icmp permit any dmz"
You have an access-list on your pix for the dmz interface called acl_dmz but the access-list only controls traffic that goes THROUGH the pix not traffic with a destination address of the pix interface. To control icmp for that traffic you use the above command.
Jon
Gatling_uk Mon, 12/08/2008 - 04:10
Thanks, have added that. Unfortunately the problem remains though..
Jon Marshall Mon, 12/08/2008 - 04:20
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay this is bit of a stubborn one. To recap
1) You have now got "icmp permit any dmz" on your pix
2) Your servers have got 10.10.2.1 as their default-gateway.
3) The servers ip address is taken from the 10.10.2.x subnet and the subnet mask on the servers is 255.255.255.0
4) The server you are testing from and the pix dmz interface are connected into one of the gi1/043 - 46 interfaces on the 3750g.
If all of the above
1) Ping the pix interface from a server and then check the arp caches on both the server and the pix. Do you see the mac-addresses in there ?
2) Have you tried to ping something on the inside of the pix from a server in the DMZ and vice-versa.
Other than that we may need to look at packet capture.
You said earlier in one of your replies
"1) that's correct, but no traffic reaches the dmz interface on the pix from the switch, it is not strictly icmp traffic that is the problem."
How have you verfied that no traffic is reaching the DMZ interface.
Finally can you confirm that the DMZ interface is up/up.
Jon
Gatling_uk Mon, 12/08/2008 - 04:56
All of the first 4 points are correct.
The mac addresses do not appear in the arp cache on either of the servers or the firewall.
I cannot ping anything on the inside interface of the pix.
I have verified nothing is reaching the pix by the observing the input/output counters as I send data.
Jon Marshall Mon, 12/08/2008 - 05:02
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Christopher
Can you try pinging the server from the pix ?
"ipconfig /all" from the server you are using to test.
Can you post a "sh ip int brief" from the 3750 ?
Sorry to ask for all this info but it is needed.
Jon
Gatling_uk Mon, 12/08/2008 - 05:14
I can't ping the server from the pix.
I can ping one server from another in the dmz, which goes through the 3750, but I can't ping the 3750 from the servers, on either the vlan 1 ip address, or the vlan 99 ip address (i have given vlan 99 an ip address in the 10.10.2.x range again). I can't ping the servers from the switch either.
IPconfig/all on server 1 reads:
ip address: 10.10.2.100
subnet mask: 255.255.255.0
default gateway: 10.10.2.1
primary dns: 10.10.1.50
secondary dns: 10.10.1.51
I can ping server 2 on address 10.10.2.101
Jon Marshall Mon, 12/08/2008 - 05:39
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Can you post the FULL config for the 3750g switch.
Jon
Gatling_uk Mon, 12/08/2008 - 05:48
version 12.2
no service pad
hostname switch2
enable secret 5 $1$rMLz$axMm2ss8kb3k3f1
no aaa new-model
ip subnet-zero
no file verify auto
vlan 5
name vMotion
vlan 29
name Colo Network
vlan 77
name Management
vlan 99
name DMZ
interface Vlan1
interface Vlan5
no ip address
interface Vlan77
no ip address
interface Vlan99
ip address 10.10.2.250 255.255.255.0
ip classless
no ip http server
control-plane
line con 0
password 7 121E551510075F
login
line vty 0 4
password 7 045C5B040D2D1F
login
line vty 5 15
login
end
Jon Marshall Mon, 12/08/2008 - 05:53
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Just to rule out a switch issue can you
1) remove "ip default-gateway 10.10.1.1"
2) add "ip route 0.0.0.0 0.0.0.0 10.10.1.1
3) enable ip routing on the 3750 eg "ip routing" and then retest ping from server in vlan 99 to vlan 99 interface on switch.
Jon
Gatling_uk Mon, 12/08/2008 - 06:25
I have done all of the above.
I can now ping the switch from the servers, and the servers from the switch, but I still cannot ping the dmz interface from either the switch or the servers, or vice versa.
I also still cannot ping hosts on the internal network from the dmz servers.
Jon Marshall Mon, 12/08/2008 - 06:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you want to try and ping inside servers from DMZ
1) add this to pix config "static (inside,dmz) 10.10.1.0 10.10.1.0 netmask 255.255.255.0
2) Shutdown the vlan 99 interface on your switch.
Jon
Gatling_uk Mon, 12/08/2008 - 07:11
I unfortunately cannot do that right now.
I have just noticed one other thing though..
When I add the port on the 3750 that the pix dmz interface patches into to the dmz vlan it drops the entry from the cam table, but it still has an entry for the mac address associated with another port that connects to a management switch.
To clarify, port 43 on the switch is added to vlan 99 and instantly it loses that association in the cam table. There is another entry in the cam table to the dmz int mac-address via int 17 on the switch which connects to a management network.
Jon Marshall Mon, 12/08/2008 - 07:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Okay, that's not right. Are you sure the cables are connected in correctly. It may be time to go back to basics. What happens if you allocate int 17 to vlan 99 ?
Jon
Gatling_uk Mon, 12/08/2008 - 05:15
switch2#sh ip int b
Vlan1 10.10.1.250 YES NVRAM up up
Vlan5 unassigned YES NVRAM up up
Vlan77 unassigned YES NVRAM up up
Vlan99 10.10.2.250 YES manual up up
GigabitEthernet1/0/1 unassigned YES unset up up
GigabitEthernet1/0/2 unassigned YES unset up up
GigabitEthernet1/0/3 unassigned YES unset up up
GigabitEthernet1/0/15 unassigned YES unset up up
GigabitEthernet1/0/16 unassigned YES unset up up
GigabitEthernet1/0/17 unassigned YES unset up up
GigabitEthernet1/0/18 unassigned YES unset up up
GigabitEthernet1/0/19 unassigned YES unset up up
GigabitEthernet1/0/20 unassigned YES unset up up
GigabitEthernet1/0/21 unassigned YES unset up up
GigabitEthernet1/0/22 unassigned YES unset up up
GigabitEthernet1/0/23 unassigned YES unset up up
GigabitEthernet1/0/24 unassigned YES unset up up
GigabitEthernet1/0/25 unassigned YES unset up up
GigabitEthernet1/0/26 unassigned YES unset up up
GigabitEthernet1/0/27 unassigned YES unset up up
GigabitEthernet1/0/28 unassigned YES unset up up
GigabitEthernet1/0/29 unassigned YES unset up up
GigabitEthernet1/0/30 unassigned YES unset up up
GigabitEthernet1/0/31 unassigned YES unset up up
GigabitEthernet1/0/32 unassigned YES unset up up
GigabitEthernet1/0/33 unassigned YES unset up up
GigabitEthernet1/0/34 unassigned YES unset up up
GigabitEthernet1/0/35 unassigned YES unset up up
GigabitEthernet1/0/36 unassigned YES unset down down
GigabitEthernet1/0/37 unassigned YES unset down down
GigabitEthernet1/0/38 unassigned YES unset down down
GigabitEthernet1/0/39 unassigned YES unset up up
GigabitEthernet1/0/40 unassigned YES unset up up
GigabitEthernet1/0/41 unassigned YES unset up up
GigabitEthernet1/0/42 unassigned YES unset down down
GigabitEthernet1/0/43 unassigned YES unset up up
GigabitEthernet1/0/44 unassigned YES unset up up
GigabitEthernet1/0/45 unassigned YES unset up up
GigabitEthernet1/0/46 unassigned YES unset up up
GigabitEthernet1/0/47 unassigned YES unset down down
GigabitEthernet1/0/48 unassigned YES unset down down
GigabitEthernet1/0/49 unassigned YES unset down down
GigabitEthernet1/0/50 unassigned YES unset down down
GigabitEthernet1/0/51 unassigned YES unset down down
GigabitEthernet1/0/52 unassigned YES unset down down
Gatling_uk Mon, 12/08/2008 - 05:52
One other thing..
The pix knows that the 10.10.2.0 network is directly connected to it out of it's dmz interface, but I can't ping 10.10.2.250 (dmz vlan ip address on the switch) from the pix.
