Auto-MDIX router support
Dec 8th, 2008
Hi, Please let me know weather 3845 router support Auto-MDI&X feature or not.
If yes then how to configure it.
royalblues Mon, 12/08/2008 - 05:43
If Auto-MDIX feature is available in a device, then it will be enabled by default
Best thing would be to connect a PC to the router ethernet using a straight cable and see if it works. If it does then it supports
However it does not indiacte anything in the " sh controller gigabit ethernet " command
jitendra.kansal Mon, 12/08/2008 - 05:57
Hi Narayan,
thanks for your valuable suggestion but my question is still not solved-
I would like to connect two 3845 routers back to back but thru straigth cable but its not working.
Can i connect it thru straight cable if yes then how?
I heared abt MDI/MDIX command so query is that weather it is working on 3845 router or not.
Jitendra Gupta
royalblues Mon, 12/08/2008 - 06:07
The command is mdix auto but i do not see it available in the 3545 code
