12-08-2008 05:56 AM - edited 03-06-2019 02:51 AM
Hi!
Can any body help with information about values in output of
show platform port-asic stats miscellaneous
Cisco IOS command?
WBR, Alexey Misyurenko
12-08-2008 05:46 PM
Please specify what switch platform you are using.
Normally with show platform commands, they are not documented because they're used for low-level troubleshooting.
Can you elaborate on what problem are you trying to solve by looking at these commands?
12-09-2008 12:41 AM
My platform is Cisco Catalyst WS-C3750G-24TS.
Output of
is
Port-asic Misc Statistics
TxBufferFullDropCount 0
TxBufferFrameDescBadCrc16DropCount 0
TxBufferBandwidthDropCount 0
TxQueueBandwidthDropCount 0
TxQueueMissedDropStatistics 0
SneakQueueDropCount 0
RxBufferDropDestIndexCount 1274650
LearningQueueOverflowFrames 0
LearningCamSkipCount 0
ReceivePortFifoFullDropStats[0 ]: 0
ReceivePortFifoFullDropStats[1 ]: 0
ReceivePortFifoFullDropStats[2 ]: 0
ReceivePortFifoFullDropStats[3 ]: 0
May be it is not problem but
is not empty and it grow.
12-09-2008 01:43 AM
RxBufferDropDestIndexCount is a global counter (for all the ports in the asic) of various frames that were dropped on ingress. This could be due to various reasons like frames received on an STP blocked port, frames that violate port-security and many more such cases.
So this is typically normal to see on a switch and nothing to worry about unless you suspect a problem with dropped traffic.
12-09-2008 12:53 AM
On another point we have Catalyst 3560.
And on it another counter is not ziro and it also grow.
TxBufferFullDropCount 1967599995
