Warning message
Sip Trunking with more than one provider.
Answered Question
Dec 8th, 2008
Hi, how can I configure more than one sip provider? Currently I have callcentric configured under sip-ua. Do I add the additional info under the same sip-ua or can you add a second sip-ua like sip-ua 2? also how would I route the calls either as a secondary or an additional line on the system..
Correct Answer by Nicholas Matthews about 8 years 8 months ago
At this time you can only register to one at a time, and for backup purposes they have to be the same username and password.
Here's an example of a backup registrar example:
sip-ua
authentication username xxxx password yyyy
registrar dns:abc.net expires 3600 <-- Primary SIP Provider
registrar dns:xyz.net expires 3600 secondary <-- Backup SIP provider
Overall Rating: 5 (1 ratings)
vgioia5090 Fri, 12/12/2008 - 20:30
hi and thanks, i guess what you meant was that i can add additional registrars to the sip-ua and then create dial peers with that target, right? if so then can i set priority so if i dial 1800XXXXXXX and one provider is down, it will go out the second? could you give me a sample of what the config might look like?
thanks
Correct Answer
Nicholas Matthews Sat, 12/13/2008 - 13:19
  • Red, 2250 points or more
sip-ua
