How do I change what IOS to load on C2960?
Dec 8th, 2008
I have just uploaded a new IOS to my C2960 switch, but it still uses the old IOS file, how can I change this?
2960#sh flash:
Directory of flash:/
2 -rwx 5 Mar 1 1993 05:34:25 +00:00 private-config.text
4 -rwx 6370034 Mar 1 1993 05:33:24 +00:00 c2960-lanbase-mz.122-44.SE3.bin
5 -rwx 1957 Mar 1 1993 05:34:25 +00:00 config.text
7 drwx 192 Mar 1 1993 00:10:50 +00:00 c2960-lanbase-mz.122-35.SE5
32514048 bytes total (17807360 bytes free)
CBSO_2960#sh boot
BOOT path-list : flash:c2960-lanbase-mz.122-35.SE5/c2960-lanbase-mz.122-35.SE5.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
Auto upgrade path :
NVRAM/Config file
buffer size: 65536
Overall Rating: 4 (2 ratings)
Collin Clark Mon, 12/08/2008 - 06:49
In config mode, enter the following command-
boot system flash:c2960-lanbase-mz.122-44.SE3.bin
Then save the config and reload. It should come up with the new IOS.
Hope that helps.
whiteford Mon, 12/08/2008 - 06:54
Any reason why I can't add "switchport trunk encapsulation dot1q" to to int gig0/1 port?
I can do "switchport mode trunk" only, is it dot1q only be default or something?
Jon Marshall Mon, 12/08/2008 - 07:00
The 2960 only supports 802.1q trunking ie. it does not support ISL trunking. So you don't get the option to set dot1q as it is the only one available.
Jon
