access remote Peer application through WebVPN
Dec 8th, 2008
Site A <-> Site B
Hi All
I setup a IPSec VPN tunnel between 2 Site (A,B) with ASA 8.02. I also setup WebVPN in Site A ASA.
I access all services in Site A through WebVPN.
1. Now, I have other web application in Site B, Can I access this web applicatopn through WebVPn (Site A)?
2. If yes, how to do it? because I think no IP from pool is allocated to WebVPN client
thank
JORGE RODRIGUEZ Mon, 12/08/2008 - 12:56
  • Green, 3000 points or more
Yes it is possible, there is no link per say depicting webvpn as a client source and L2L tunnel example, but look at this link, same principle the difference is the client is using Cisco VPN client and can access resources in PIX3.. the L2L termination is between PIX1 and PIX3, vpn client comes through PIX1.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008046f307.shtml
You already have exsiting L2L tunnel between A and B sites. Now you can simply use same-security-traffic permit intra-interface and add your WebVPN pool network to your L2L tunnel interesting traffic nat exempt acl.
Jorge
