ISIS over etherchannel on ASR1006
Dec 8th, 2008
I`m trying to run isis over etherchannel subinterface on an ASR1006 and i`m getting the following error message:
CLNS-3-BADPACKET: ISIS: LAN L2 hello, Duplicate system ID detected....
Here is my ethernchannel config:
interface Port-channel10
no ip address
negotiation auto
interface Port-channel10.110
description switch
encapsulation dot1Q 110 primary GigabitEthernet0/2/0 secondary GigabitEthernet2/2/0
ip address 192.168.6.245 255.255.255.252
interface Port-channel10.120
description router2
encapsulation dot1Q 120 primary GigabitEthernet0/2/0 secondary GigabitEthernet2/2/0
ip address 192.168.6.249 255.255.255.252
ip router isis
And her`s the "debug isis adj"
*Dec 8 07:58:03: ISIS-Adj: Sending L2 LAN IIH on Port-channel10.120, length 1497
*Dec 8 07:58:03: ISIS-Adj: Rec L2 IIH from 0023.04bb.7bc9 (Port-channel10.120), cir type L2, cir id 1720.3107.9197.02, length 1497
*Dec 8 07:58:03: ISIS-Adj: Duplicate system id
*Dec 8 07:58:06: ISIS-Adj: Sending L2 LAN IIH on Port-channel10.120, length 1497
*Dec 8 07:58:06: ISIS-Adj: Rec L2 IIH from 0023.04bb.7bc9 (Port-channel10.120), cir type L2, cir id 1720.3107.9197.02, length 1497
*Dec 8 07:58:06: ISIS-Adj: Duplicate system id
*Dec 8 07:58:08: ISIS-Adj: Rec L2 IIH from 001f.ca04.cee8 (Port-channel10.120), cir type L2, cir id 1720.3107.9197.02, length 1497
*Dec 8 07:58:09: ISIS-Adj: Sending L2 LAN IIH on Port-channel10.120, length 1497
*Dec 8 07:58:09: ISIS-Adj: Rec L2 IIH from 0023.04bb.7bc9 (Port-channel10.120), cir type L2, cir id 1720.3107.9197.02, length 1497
*Dec 8 07:58:09: ISIS-Adj: Duplicate system id
Does anyone one the solution??
Kristian
Giuseppe Larosa Mon, 12/08/2008 - 09:06
  • Hall of Fame,
    Founding Member
Hello Kristian,
Verify the IS-IS system-id of all three devices involved in vlan 120.
The system-id have to be different and unique in the IS-IS domain.
Another possibility is that some other device is sending back ASR's own hellos so it complains about duplicated IS-IS ID.
Hope to help
Giuseppe
klauritzen Wed, 12/10/2008 - 07:40
Thanks for the reply.
The ISIS system ID is unique.
I`m starting to think there might be a problem running ISIS over etherchannel...
I tried to look for an configuration example on this but couldn't find anything. I might have to check with cisco if ISIS over etherchannel is supported.
Kristian
Giuseppe Larosa Wed, 12/10/2008 - 09:30
  • Hall of Fame,
    Founding Member
Hello Kristian,
I don't know if it is supported on ASR 1000 but we use IS-IS and on bundles of GE ports with C6500 it is supported, actually our etherchannels are L2 trunks and the IS-IS configuration is issued in the SVI Vlans.
if the system ids are unique the only chance is that someone is bridging traffic of the two vlans so that your ASR is receiving on vlan x its own hellos sent out vlan y.
Hope to help
Giuseppe
