ASA - reconfiguring interfaces help
jigsaw2026
I have a trunk port on one interface, with 2 sub-interfaces. I am actually decomissioning one of the vlans, so I would like to remove the sub-interfaces and make it a regular interface with the remaining vlan.
Setup as follows:
interface GigabitEthernet0/1
speed 1000
duplex full
no nameif
no security-level
no ip address
interface GigabitEthernet0/1.3
vlan 30
nameif inside
security-level 100
ip address 10.20.0.1 255.255.0.0 standby 10.20.0.2
interface GigabitEthernet0/1.10
vlan 10
nameif storage
security-level 85
ip address 10.24.0.1 255.255.0.0 standby 10.24.0.2
I would like to get to:
speed 1000
duplex full
nameif storage
security-level 85
I have an active/standby failover. I would like to readdress this with minimal downtime, but I'm unsure how to do this without confusing the failover. I was thinking that I could do the following:
1) On the standby unit, remove both sub-interfaces and readdress interface as above
2) Failover primary to standby
3) On primary, remove both sub-interfaces and readdress interface as above.
4) Fail back to primary
With this plan I am worried that
-standby unit will complain that it's not synched
-failver from primary will not occur because standby interfaces will no longer exist
Or is it necessary for me to admin shut down the primary interface (will this cause failover???), readress and then bring back up again, no failover required...
Can anyone think of a good way of going about this?
Many thanks,
J
Collin Clark
I don't think the firewall will failover when you make interface config changes. If you're really concerned, you could reboot/shut down the failover device and while it's down/rebooting, you could make your configuration changes. Once the standby device is online it will sync the config with the primary.
Hope that helps.
Thank you for your response. The problem is that I do not really want any downtime while I'm doing it (for the remaining vlan) - which is why I thought to failover - but I guess that's not possible?
IMO by using failover to keep uptime during the reconfig, you greatly increase your risk in things getting FUBAR'd.
