Problem with access list
Dec 8th, 2008
(inside network) one switch+ Router+firewall+router+Switch(outside network)
outside network have total four users
inside one printer
all four users have to access the one printer with single ip address
out side starting with 10.1.1.1
10.1.1.2,10.1.1.3,10.1.1.4
inside printer ip address 3.185.56.1
outside interface ip address starting with 10.x.x.x
inside ip address 3.x.x.x
how to create access list for four users and
how write nat from outside network to inside
vmoopeung Fri, 12/12/2008 - 14:09
  • Bronze, 100 points or more
You can use PAT to configure the outside networks to access the printer in the inside network using single IP address.
Static PAT Example:
In order to redirect Telnet traffic from the outside interface (10.1.2.14) to the inside host at 10.1.1.15, enter this command:
hostname(config)#static (inside, outside) tcp 10.1.2.14 telnet 10.1.1.15 telnet netmask 255.255.255.255
For configuring the access list:
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfip.html#wp1067360
