PIX Backup Image in Flash
Answered Question
Dec 8th, 2008
Can anyone tell me the boot behavior of the PIX when it comes to recovering from a corrupt/invalid image in flash?
Example: In flash I have 2 images:
image1.bin
image2.bin
What (if possible) are my options to have 2 images and a boot sequence so it tries a specific image first. This would be useful in an upgrade situation in case the newly applied image is corrupt or for any other reason can't boot the PIX.
This may be the default behavior - I'm just looking for confirmation or more details. Do I specify it using: "boot system flash:/image1.bin" and then will it try another if "image1.bin" is not successful?
Correct Answer by Jon Marshall about 8 years 5 months ago
You should be able to enter multiple boot commands with the same storage eg.
boot system flash:/
boot system flash:/
etc..
Jon
Overall Rating: 5 (1 ratings)
mhcraig Mon, 12/08/2008 - 10:36
Sorry about that - I'm running v 8.0(3) on a PIX 525.
One issue I'm going to have is that the PIX only has 16MB of flash and between the ASDM and the Image itself I don't have enough room to store an alternate system boot image. Not sure if it's upgradable to 32mb+ I'll have to check. (Obviously I could always delete the asdm image and clear room for an upgrade - just thinking longer term.)
After reading the link you provided I'm still unclear on the "boot system flash:/pix803.bin" syntax. Can I enter multiple flash locations (repeat that command) or do I have to select a different location/medium? It seems the PIX525 can't boot from TFTP(?).
Thanks for your advice.
Correct Answer
Jon Marshall Mon, 12/08/2008 - 11:02
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
boot system flash:/
boot system flash:/
etc..
Jon
