12-08-2008 10:19 AM - edited 03-15-2019 02:57 PM
I was looking around in the RTMT for our system and found that there is an alert regarding the 'Cisco Messaging Service' being down. I verified that it is activated but not running in the serviceability page. I was going to restart the service but since I cannot find any documentation as to what it actually does I did not want to take a chance on restarting it. If anybody knows what that service is or does and could point me to some documentation I would appreciate it.
Thanks - Matt
Solved! Go to Solution.
12-08-2008 10:43 AM
no, SMDI is a legacy VM integration and that's the main purpose of the CMI
there is no need to start the service for a CUC integration, or unity, or CUE for that matter
java
if this helps, please rate
12-08-2008 10:24 AM
it's used for legacy VM integrations, SMDI.
if you're not using any, there is no need to start the service
java
12-08-2008 10:39 AM
Thanks for the reply. We are using Cisco Unity Connection for our voice mail. Do you know if that would be considered a legacy VM?
Matt
12-08-2008 10:43 AM
java
12-08-2008 11:16 AM
Thank you again. That clears it up for me, just one more thing. Should I set that so that the service is no activated or does it not really make any difference? It has been functioning this way for a couple of months now so I don't see the harm but if it will clear up the alerts in the RTMT and not afect anything I would prefer to just change it.
Thanks - Matt
12-08-2008 11:23 AM
the recommendation is to leave it stopped unless going to use it.
same as CAPF, if not using it, leave it stopped.
simply ignore the alerts
java
12-08-2008 11:30 AM
Thank you very much.
