6500 Flexwan / T1 Card Issue
Dec 8th, 2008
6509 IOS Ver 12.1(13)E16
Sup 1 w/ MSFC2 Daughter board
We recently replaced the chassis, flexwan, and the PA-MC-2T1 T1 card.
When we perform a show mod, only the flexwan shows up not the card, when seating the flexwan into the chassis the "enable" light on the T1 card blinks once during the init phase but never comes back on after the flexwan is initialized.
conf t
card type command is unrecognized
Any ideas?
vmiller Mon, 12/08/2008 - 15:37
Based on the evidence, that card is not supported. Are you running native or hybrid?
xcz504d1114 Mon, 12/08/2008 - 15:46
Running Native IOS on the 6509
The flexwan card is the same as one in our other core router, HW Vers 1.5, we popped 2 T1 cards in it with the same result and a DS3 card with the same result. I'm starting to think it's a hardware issue, but I want to make certain I am ruling out any human error here and that I'm not just overlooking some command to enable the card or anything silly.
vmiller Tue, 12/09/2008 - 08:18
i ran your hardware config through one of the tools, It reported that the config you propose is not supported. Its not so much the flexwan as it is the specific line card.
