Import PIX 501 config to ASA 5505
Answered Question
Dec 8th, 2008
Is there anything special that needs to take place to Import a PIX 501 (IOS Version 6.3) config to an ASA 5505 appliance or is it as simple as uploading the config?
Correct Answer by Jon Marshall about 8 years 7 months ago
Greg
Not it's not unfortunately because your pix is running 6.4 and the ASA 5505 will be running a minimum of 7.x code and there were quite a few changes. Note that a lot of existing commands would work but some won't. Attached is a link to a doc for upgrading from pix to ASA which talks about both a manual method and a tool assisted version -
http://www.cisco.com/en/US/docs/security/asa/migration/guide/pix2asa.html
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 12/08/2008 - 11:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Greg
Jon
gda@srcnetwork.com Tue, 12/09/2008 - 09:25
Thanks Jon, I kind of suspected that. I will take a look at the link in detail and go from there. Thanks again for your help!
