Cat 6k:Inline Power Module - PS volatage bad, cpu @ 85%
Answered Question
Dec 8th, 2008
My Cat6k running hybrid mode 8.x in the Sup32 is giving the below error and pushing the cpu to 85%.
SYS-3-SYS_LCPERR3:Module 4: Inline Power Module - PS volatage bad: Module needs troubleshooting or
Is there any method to stop this module logging the 100's of message per hr? I don't use inline power for anything. The error logging is over driving the CPU.
We plan to replace it, but it will be several days before this is possible.
Correct Answer by Giuseppe Larosa about 8 years 7 months ago
Hello Doug,
if you don't use the module 4 you could
set module power down 4
otherwise you need to disable logging to your telnet session
set logging session disable
and to your console
set logging console disable
or you can try to change the severity level
set logging level sys 6
for more details see
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/catos/8.x/configuration/guide/logging.html#wp1020288
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Mon, 12/08/2008 - 11:28
  • Hall of Fame,
    Founding Member
Hello Doug,
and to your console
Hope to help
Giuseppe
