ICMP unreachable, rate-limit command
Dec 8th, 2008
Hi !
I'm currently working on projet of network hardening.
Based on Cisco security best pratice, I see it's recommand to rate limit genaration of ICMP unreachable message to prevent DoS attack. (according to document : http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a0080825564.pdf page 74)
On Catalyst 6509 run IOS 12.2(17r)SX5 I see to possible way to rate-limit ICMP messages if mls QoS is running.
1- mls rate-limit unicast ip ICMP unreachable acl-drop 100 10 (enable by default, according to document : http://www.cisco.com/application/pdf/en/us/guest/netsol/ns171/c649/ccmigration_09186a0080825564.pdf page 74)
mls rate-limit unicast ip ICMP unreachable no-route 100 10
2- ip ICMP rate-limit unreachable <millisecond> (500 ms is default parameters, which permit 2 paquets per seconds, also enable by default if I'm base on : http://www.cisco.com/warp/public/707/cisco-sn-20030125-worm.shtml, ACL for IOS section)
Which one of those command have precedence over the other one ?
Which one is better over the other one ?
With the mls rate-limit option, we have the possibility to check default parameter with : "show mls rate-limit" command is exist equivalent for : "ip ICMP rate-limit unreachable"
We have also Catalyst 3550 switches, on which we have to rate-limit genaration of ICMP unreachable message for same reason as 6509. I understand the :"ip ICMP rate-limit unreachable" command is my only option "under "mls " the only option I have is QoS or aclmerge. Under thoses parameter I have no way to rate-limit ICMP message generation....
I have check in running-configuration I did not find any reference to ICMP rate-limit command, I hope this is active like explain in document http://www.cisco.com/warp/public/707/cisco-sn-20030125-worm.shtml, ACL for IOS section, (Version 12.2(44)SE3) but I would like to be able to confirm if any show command exist to confirm this.
thanks a lot !
