Allowing Pings on a NAT Global
johnnylingo
Level 5
Level 5
I want to allow pings to and from a NAT Global public IP on an ASA running 8.0(4) code. Here is the config:
access-list acl_outside extended permit icmp any any echo
access-list acl_outside extended permit icmp any any echo-reply
access-list acl_outside extended deny ip any any
access-group acl_outside in interface outside
icmp permit any echo outside
icmp permit any echo-reply outside
I am able to ping the ASA's outside interface, but not any of the NAT Global addresses. What am I missing?
5 Replies 5
Jon Marshall
John
Could you give an example of one of your global NAT's or better yet could you post the config of the ASA together with some details on which IP address you are trying to ping.
Jon
Here's the NAT Global config. It's pretty straightforward.
global (outside) 1 1.2.3.4
nat (inside) 1 192.168.100.0 255.255.255.0
The error messages says ICMP type 8 is denied to 1.2.3.4
John
This is a dynamic NAT setup. So you will not be able to be on the outside of the firewall and ping 1.2.3.4 because the firewall doesn't know which ip address from the 192.168.100.x address you want it to translate to.
To ping from the outside to the inside you will need a static eg.
static (inside,outside) x.x.x.x 192.168.100.x
where x.x.x.x is an IP address presented to the outside and 192.168.100.x is an IP address on the inside that maps to x.x.x.x.
Jon
OK, that makes sense. We have another address that is a global combined w/ static for our e-mail server:
global (outside) 2 5.6.7.8
nat (inside) 2 10.10.10.2 255.255.255.255
static (inside,outside) tcp 5.6.7.8 smtp 10.10.10.2 smtp netmask 255.255.255.255
static (inside,outside) tcp 5.6.7.8 pop3 10.10.10.2 pop3 netmask 255.255.255.255
static (inside,outside) tcp 5.6.7.8 imap4 10.10.10.2 imap4 netmask 255.255.255.255
I take it since this has a global, I would have to redirect ICMP echos to the internal IP of 10.10.10.2?
John
"I take it since this has a global, I would have to redirect ICMP echos to the internal IP of 10.10.10.2?"
Not sure exactly what you mean here. You can't redirect ports with ICMP as far as i know. So you would need a straight static ie. not specifying individual ports.
Jon
