Change password tacacs access for first time users
Dec 8th, 2008
Hi to all,
Is it posible to configure the TACACS on the ACS 4.1 in order to request the users that access to a device by the first time to change their password? for example if i create a user named "test1" and with password "123456" in the first time they loggin a device the ACS ask them for a new password.
Thanks in advance!
alfonso.cornejo Mon, 12/08/2008 - 12:56
Hi to all,
I found how to do it, it is under System Configuration > Local Password Management. In Remote Change Password uncheck Disable TELNET Change Password against this ACS and return the following message to the users telnet session. But do you know if it posible to make this work with SSH ?????
Thanks in advance.
