Jon Marshall Mon, 12/08/2008 - 12:58
To add to Collin's post, also depends on the SDM template you use -
MAC Addresses
• Desktop Default SDM template: 6K
• Desktop Routing SDM template: 3K Desktop VLAN SDM template: 12K
• Aggregator Default SDM template: 6K Aggregator Routing SDM template: 6K
• Aggregator VLAN SDM template: 12K
• WS-C3750G-12S Aggregator VLAN SDM template: 20K
Full link - http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/prod_qas09186a00801b0971.html
L2 performance table near the bottom.
Jon
yuchenglai Mon, 12/08/2008 - 13:11
Think I have found a way to get this figure. Please confirm that this is the correct way.
At the end of a "show mac address-table" output is:
Total Mac Addresses for this criterion: 2074
The end of a "show mac address-table" output is:
Total Mac Address Space Available: 3456
Adding the two figures above yields 5530
Would this be one way to find out the maximum number of mac addresses a 3750 switch can support?
Collin Clark Mon, 12/08/2008 - 13:37
You're probably using the default SDM template which is 6K (per Jon). show sdm prefer will show you what template you're using.
Hope that helps.
