NAT incoming VPN Tunnel
Answered Question
Dec 8th, 2008
I have a new vpn tunnel that I would like to NAT to the internal network address space. The new tunnel is coming from 172.31.17.0 and the existing LAN on the ASA is 172.31.16.0 Is there a good solution to make the incoming tunnel hav a source address from the 172.31.16.0 network to access other resources?
Correct Answer by Jon Marshall about 8 years 5 months ago
Tom
Assuming it is a site-to-site VPN and assuming a spare IP address of 172.31.16.10
nat (outside) 2 172.31.17.0 255.255.255.0 outside
global (inside) 2 172.31.16.10
OR if you want to use the interface address
global (inside) 2 interface
Note i have used a nat-id of 2 in the example, just use a nat-id that is unused.
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 12/08/2008 - 13:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Tom
Is this a site-to-site VPN tunnel ?
Do you have a spare IP address in the 172.31.16.x subnet or do you want to use the inside interface address on the ASA ?
Jon
TJ Kelly Mon, 12/08/2008 - 13:38
Jon,
I could use either. The interface is 172.31.16.1 or I could utilize an open IP on the inside.
Tom
Correct Answer
Jon Marshall Mon, 12/08/2008 - 13:44
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Tom
Jon
TJ Kelly Mon, 12/08/2008 - 14:14
Jon,
Thanks for your help. This will work.
Tom
