12-08-2008 01:32 PM - edited 03-04-2019 12:38 AM
Is it possible to configure LFI for traffic passing over an Ethernet interface? If so how?
12-08-2008 02:51 PM
I'm afraid it's not possible. It was designed for low-speed serial links using MLPPP or Frame-Relay/ATM.
HTH,
__
Edison.
12-08-2008 05:51 PM
BTW: depending on your needs, working with IP and Ethernet, controlling MTU might be an alternative to needing LFI.
12-09-2008 05:14 AM
Thanks for your response, how can I verify fragmentation on an Ethernet interface, I am concerned that data might be holding up voice packets.
12-09-2008 05:45 AM
Not quite sure what you mean by "how can I verify fragmentation on an Ethernet interface". If your concern is VoIP on Ethernet, Ethernet is normally fast enough that packet size and fragmentation isn't an issue provided you can place your VoIP packets into a separate interface egress queue with priority or guarantee bandwidth access. Many managable switches (and routers) often support some QoS features.
