WCS - Guest User Creation
Dec 8th, 2008
Hello. I have a question related to the Lobby Ambassador login in WCS and creating user accounts in an environment using a guest Anchor controller. Specifically, if a 'lobby ambassador' is logged into WCS from 2 timezones away (anchor is in same location as WCS) creating a user, they will see the local time of the WCS (for start/stop times), correct? Is there a way to make it present the local time to the lobby ambassador so they don't have to figure out the correct start/stop times for their location?
Hopefully this question makes sense.
Thank you for your time and assistance,
Jeff
Pushkar Sambhoos Mon, 12/08/2008 - 23:28
Lobby admins created guest users are always in the WCS timezone. If controllers are in another timezone, the lobby admin needs to adjust the time accordingly while creating guest users.
Trending Topics - Security & Network
