3560 PoE-24 issue
Dec 8th, 2008
Good day gentlemn
I have a 350 with a minimal config on it. I am trying to ping from my 3 VLAN to my 252 VLAN on this switch and it will not allow it. I am sure I am doing something wrong, But I cannot figure it our or even if I can do so.
Here is the config I have, if anyone can help I would be mighty grateful
PHXEMTCSQA003#sh run
Building configuration...
Current configuration : 3384 bytes
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
hostname PHXEMTCSQA003
logging buffered 8192 debugging
enable secret 5 $1$6XPe$fx1DT5Y4A51GuzUkzHuZN0
username local secret 5 $1$gKrb$3ZFzFUZqWdfftVm/mq1PO0
no aaa new-model
clock timezone EST -5
ip subnet-zero
spanning-tree mode rapid-pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 3
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
no snmp trap link-status
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
description **TSC_QA_UPLINKS TO 7206**
switchport access vlan 252
interface FastEthernet0/24
interface GigabitEthernet0/1
shutdown
interface GigabitEthernet0/2
shutdown
interface Vlan1
no ip address
no ip route-cache
interface Vlan3
description **TSC_QA_GATEWAY**
ip address 172.16.3.1 255.255.255.0
interface Vlan251
no ip address
no ip redirects
no ip proxy-arp
no ip route-cache
shutdown
interface Vlan252
description **TCS_QA_Uplink**
ip address 172.16.252.1 255.255.255.0
no ip classless
no ip http server
no ip http secure-server
Jon Marshall Mon, 12/08/2008 - 14:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have you configured ip routing ie.
3560(config)# ip routing
Jon
scott.cummins Mon, 12/08/2008 - 14:47
I have now, Also, I did not have anything connected to VLAN 252, once I did I could ping it. I haven't installed it properly yet to see if I can route traffic to it. As soon as I do I will probably be back..
Thanks Jon
Jon Marshall Mon, 12/08/2008 - 15:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Scott
No problem, glad you got it working.
Jon
