Redirect show command output
Dec 8th, 2008
Is it possible to use "show <command> | include example" and then output (tee) the results to file? I've tried multiple variations with no luck so far, just wondering if there is some special way you have to enter the command to combine the two options.
Mark Yeates Mon, 12/08/2008 - 14:42
I don't think a "| tee" can be used in conjunction with another pipe.
- With one tee it works just fine
Router#sh log | tee tftp://
- When I question mark after an exclusion it does not display the tee option.
Router#sh run | exc una ?
- This shows the running config but does not tee to the TFTP server
Router#sh run | exc una | tee tftp://
