subinterface
Answered Question
Dec 8th, 2008
how to create subinterface on 2800 router? what is the purpose of creating subinterface? thanks!
Correct Answer by viyuan700 about 8 years 6 months ago
attaching 2 documents hope it helps you
google it for Router on stick or inter vlan routing you will get some utube video also those videos will be better than these document
Overall Rating: 5 (1 ratings)
viyuan700 Mon, 12/08/2008 - 20:14
  • Silver, 250 points or more
Suppose u want to create subinterface on your fast ethernet 0/0 port then
Config t
int f0/0.1 (instead of 0 it is 0.1 if want more 0.2,0.3etc)
you will see prompt as subinterface
then you can define ip etc
Subinterface are used for intervlan routing. So that host on vlan1 can talk to host on vlan 2.
If you are not using suninterface you need 2 fastethernet port on your router for intervlan routing.
Richard Burts Mon, 12/08/2008 - 20:23
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Oliver
Perhaps there is an aspect of the response from Vishwamurti which could be clarified. Using subinterfaces on a router FastEthernet interface configures it to do trunking and to communicate with a switch whose interface connecting to the router is configured as a trunk. Each subinterface of the router interface corresponds to a VLAN in the trunked interface from the switch.
Rick
viyuan700 Mon, 12/08/2008 - 20:54
Thanks Rick for clarifying it further.
Correct Answer
viyuan700 Mon, 12/08/2008 - 23:08
lejoe.thomas Mon, 12/08/2008 - 20:30
Oliver,
Again adding to the usage of subinterfaces. Apart from it's use in intervlan routing, sub interfaces are also used in Frame-relay networks, to divide partially meshed network into smaller fully meshed sub networks.
Point-to-Point sub interfaces are generally the preferred method in frame-relay networks.
Lejoe
Joseph W. Doherty Tue, 12/09/2008 - 04:58
Subinterfaces are also often used for ATM network too.
The key concept of subinterfaces, they allow for multiple logical interfaces off one physical interface. As other posters have described, these logical interfaces would behave much a physical interfaces connected to various networks whether they are Ethernet VLANs, frame-relay or ATM virtual circuits, etc.
A couple of issues using subinterfaces, because they share a physical interface, there are sometimes configuration restrictions compared to what might be done on the physical interface, and since they share a physical interface they also share its bandwidth.
