How to HA cisco 4503 Switch with Supervisor Engine II-Plus-TS
Dec 8th, 2008
Dear all
I have a Two cisco 4503 switch with Supervisor Engine II-Plus-TS. please help me to config the Redundant using both switch. one Core switch goes done other Core switch automatically Up.
how can i do that. my all access switch are connecting core switch via fiber up link. and all access switch are Cisco 2960. please help me.
royalblues Mon, 12/08/2008 - 22:27
Interconnect the 4503 together and form an etherchannel.
Create vlans on the switches and run HSRP between the two switches
Connect the 2960's to each of the core.
You can either use RSTP or use uplinkfast on the access switches for faster spanning tree convergence during failures.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3550/software/release/12.1_8_ea1/configuration/guide/Swhsrp.html
Narayan
sisil_glpl Tue, 12/09/2008 - 20:28
Dear Narayan
Thanks for replay. please give me ur Skype ID or Yahoo ID. i am working as a solution Specialist. my skype ID coolsisilperera. yahoo ID coolsisil.
