NM-8CE1T1-PRI configuration
Dec 8th, 2008
I know that NM-8CE1T1-PRI card can support only 128 channels. Could any one confirm whether it supports clear channel configuration.
If I configure 4 ports as channelised E1 making use of 128 channels, can I configure remaining 4 ports as clear channel supporting 2 Mbps. ?
Please provide the configuration for clear channel.
Please provide a documenation for NM-8CE1T1-PRI configuration.
drolemc Fri, 12/12/2008 - 13:44
Cisco 8-Port Channelized T1/E1 and ISDN PRI High Speed WAN Network Module
- Part number: NM-8CE1T1-PRI
- Provides channelized T1 or E1 connections or ISDN PRI connections
- Supported on Cisco 3800 series routers
-- Remote Management over
This channelized network module provides T1/E1 and ISDN support. It has 128 channels.
The T1/E1 HWICs or network module will not be operational until a card type is configured.
1. enable
2. configure terminal
3. card type {t1 | e1} slot subslot
For further information click this link.
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_11xw/fmt1e1ic.html#wp1054923
