Serial number of MCS server
Dec 9th, 2008
Hi All,
Is there any way to find out the serial number of MCS-7825-I1 on which CCM version 4.X is running? instead of seeing the serial number sticker which is on TOP of box.
regds,
aman
Overall Rating: 5 (2 ratings)
Sascha Monteiro Tue, 12/09/2008 - 01:21
  • Silver, 250 points or more
it could be the case that some hp management app is installed, sort of diagnostics, I believe you can see the serial from there
amansoi_5 Tue, 12/09/2008 - 03:40
Hi ,
Is there any way to edit the registry editor and find out serial number of box?
regds,
aman
Rob Huffman Tue, 12/09/2008 - 05:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Aman,
Just to add a touch to the good tips from Steve;
From Jamie;
"There is a service on the HP servers called "HP System Management Homepage". You need to start this and the browser mgmt interface will become available.
Look under the System Config -> System Board link and you will see the server's serial number."
There are some good ideas for 4.x servers in this thread;
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Telephony&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.2cbe9b86/0#selected_message
Hope this helps!
Rob
DANIE DU TOIT Tue, 12/09/2008 - 06:51
HP has a vbs script that reads the serial number from BIOS - It works on IBM servers too:
http://h41111.www4.hp.com/hps/carepack/emea_middle_east/en/getserial.html
If web access from the server is restricted, you could RDP/VNC to server:
Open a Notepad, paste in the following text and save file as sn.vbs (select save as type all files, not txt).
strComputer = "."
Set objWMIService = GetObject("winmgmts:" _
& "{impersonationLevel=impersonate}!\\" & strComputer & "\root\cimv2")
Set colBIOS = objWMIService.ExecQuery _
("Select * from Win32_BIOS")
For each objBIOS in colBIOS
Wscript.Echo "Manufacturer: " & objBIOS.Manufacturer
Wscript.Echo "Serial Number: " & objBIOS.SerialNumber
Next
Double click on sn.vbs and it will show the manufacturer (IBM/HP etc ) and the serial number
amansoi_5 Thu, 12/11/2008 - 17:24
Hi ,
We have got the local access to MCS and is in production.One way was to restart the system & go to System SETUP by pressing F9 but I am not getting any downtime.Moreover,customer has only one CCM i.e. PUB ,no Subscriber.
the second option as suggested by you.But is there any way to avoid installing VNC and copying these lines & running them.
regds,
aman
amansoi_5 Fri, 12/12/2008 - 05:40
Hi Julio,
Please can u give me the detail of how to do this?
regds,
aman
