Avaya PBX and HSI v4.2
Dec 9th, 2008
We have an issue with a Avaya pbx using a H323 trunk to an HSI version 4.2 The Avaya insists on using a faststart for its outgoing calls, and i can't see where in this version of HSI i can activate this.
On a similar issue, the HSI is shared with another customer using a version 4.1.3 CCM build, would faststart work with this CCM build?
And just to get my monies worth, if i set enable PI=8 in the HSI which direction of calls does it affect, towards the customer or towards the switch network
Many thanks
Chris
