Accessing the ASDM interface from internet.
Dec 9th, 2008
I have a cisco router---->ASA 5510--->Cisco 2960.
ASA inside interface is having 192.168.75.1,I can connect to ASDM through 192.168.75.1. The need is i want to access ASDM(192,168.75.1) from internet Iam having a public Ip also.
Can someone helpme out of this??
Thank You
Sriram.V
solpandor Tue, 12/09/2008 - 06:50
hi
if im reading this correctly,the router sits behind the ASA and if so, you can access the ASDM on the enabling http on the outside interface. HTe problem you might have is if you dont know which IP you will be coming from, you are leaving your ASA exposed to everybody.
try
1) http server
2) http public ip(of where you are coming from) 255.255.255.255 outside
sriramvijay Tue, 12/09/2008 - 23:36
Hi Solpandor
Thank you so much .It works. For remote access I want to enable that .
I can login to outside interface of ASA (CLi) through SSH but not through telnet.
Is it possible to telnet the ASA outside interface ??(it also has public ip).
Thank you
Sriram.v
husycisco Wed, 12/10/2008 - 01:12
  • Gold, 750 points or more
Hello Sriram,
No it is not possible to telnet the ASA's outside interface. Its not permitted because telnet is not a secure protocol. You have to use SSH.
sriramvijay Wed, 12/10/2008 - 02:15
Now Iam not able to ping the inside interface (192.168.75.1)of ASA from my PC.
I can telnet it, I can login to ASDM through 192.168.75.1 but not able to ping it??.Any Help??.
Thank You
Sriram.V
husycisco Wed, 12/10/2008 - 02:23
Add this
policy-map global_policy
class inspection_default
inspect icmp
