12-09-2008 03:18 AM - edited 03-04-2019 12:38 AM
Hi All,
In our network we are running MLPPP on major locations. The problem that we are facing is when any one of the E1 bundled in multilink flaps, the multilink got hung. The multilink stays up but we are not able to ping the other end /30 ip. In those cases, we have to remove the flapping link from the multilink. If we fail to remove the flapping link from multilink then we have to do a shut/no shut on the multilink interface to bring the services up.
I would like to know
a. Is the expected behavior in multilink?
b. Is there any workaround apart from shut/no shut.
Kindly revert.
Arun Kumar
12-09-2008 08:32 AM
We had a similar issue with multilink. We used to do a clear interface multilink
IOS upgradation of the routers however resolved the issue
Narayan
12-10-2008 08:35 AM
Hi Narayanan,
Thanks for the response. Could you please provide to which IOS you upgraded.
I am facing this problem in 7200 series router running with 12.3 (14)T7 and 12.3 (8)T8.
thanks in advance
Arun Kumar
