Ramprasad Pr Tue, 12/09/2008 - 04:55
Use GLBP instead of HSRP. It helps in both ways redundancy and loadbalancing. There won't be any interuption.
Ram
nagalingammk Tue, 12/09/2008 - 05:05
thanks Ram,
but my concern this will switch over if the line protocol gone down for any of the internet link.
as per my understanding the link will switch over only when the interface goes down.
thanks
nagalingammk Tue, 12/09/2008 - 05:15
thanks Ram,
thanks
ropethic Tue, 12/09/2008 - 05:38
Please see the attached BGP Dual Homed ISP design. This is one of the most widely used network designs for multihomed ISP connnections.
If BGP is not an option, then you can use HSRP, create two groups one primary /secondary to each other and load balance this way, and track the serial link
Much easier to allow Routing to handle LB
Joseph W. Doherty Tue, 12/09/2008 - 06:12
Your diagram indicates you're using a HSRP gateway. An easy method for the active gateway to switch to another router is to track the up/down status of another interface and adjust HSRP priority with the status of the interface. See http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094e8c.shtml for details.
The above assumes the tracked link goes down, but since your diagram show WAN interfaces as "F 0/1/1", if they're FastEthernet, you might lose connectivity to your provider but the link remains up. A newer feature of HSRP is the capability to track other objects, such as being able to ping an IP address (such as the ISP's router address). See http://www.cisco.com/en/US/docs/switches/blades/3040/software/release/12.2_44_se/configuration/guide/swhsrp.html for more details.
So far, I've been assuming you only are using one of your two Internet links, but there are ways to use both while supporting failure switch over. GLBP has already been mentioned by another poster, but it might not work well in your topology because of the limited number of "clients", i.e. the two 6500s. BGP has also been mentioned by another poster, and routing is an excellant suggestion, and should be considered, but much will depend on your equipment and enviroment with your providers. Another approach might be to use MHSRP, see http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml for more details.
