12-09-2008 05:07 AM - edited 03-13-2019 05:54 PM
Hello all.
I was wondering is there any way to display all the numbers in the corporate directory while you are typing the number on your IP phone. fore example, if i dial a colleague of mine using the number 628, next time I start typing with the number 6 the phone will suggest if i want to dial 628.
If i dial 627 at a alter time, next time i start typing with the 6 the phone will suggest 628 and 627.
What i was wondering is there any way to make the phone list all entries in the corporate directory starting with for ex. "6" when I start typing, and all that start for ex. "62" after i type 62 and so on.
I hope i explained it right :)
Thanks in advance for any help...
12-09-2008 10:59 AM
Hi Domagoj,
Part of is your request is available on CCM by default.
"if i dial a colleague of mine using the number 628, next time I start typing with the number 6 the phone will suggest if i want to dial 628."
If you dial with the Handset "on hook" and Press 6, the display will show all the numbers that you have called that begin with 6 and they can be selected and dialed accordingly :)
Hope this helps!
Rob
12-09-2008 12:45 PM
Hi Rob,
yeah thats exactly my question. I will get the list of numbers that i dialed, but i want a list of ALL numbers starting with for ex 6, regardless if i ever called them before or not! :)
Thx for helping!
Domagoj
01-06-2009 12:26 PM
I believe it will display only the numbers you have previously dialed, not all the numbers that start with a 6.
01-06-2009 01:36 PM
unfortunately as already noted that only shows dialed numbers, since it's a feature on the FW of the phone which uses the numbers that are stored on the flash memory, it really does not access CUCM info at any time for that. so you cannot have that feature, that would require rewriting the FW code to do a search on CUCM DB.
java
if this helps, please rate
01-06-2009 11:20 PM
Thanks for all the help everyone, guess its down reprogamming the code...
