Inline Vlan Pair Configuration Question?
Dec 9th, 2008
Hi,i have a Question about inline vlan pair configuration.for example if in my 6509 witch has FWSM and IDSM-2 if i want my server farm traffic(witch is vlan 2,3,4) first pass through IDSM-2 and the terminate at FWSM(interface vlan 2,3,4 has ip address in fwsm witch is default gateway of servers) is this sample configuration correct?
servers are on vlan 2,3,4
vlan 22,33,44 are for idsm-2 bridging
!!!MSFC
vlan2
vlan 3
vlan 4
vlan 22
vlan 33
vlan 44
intrusion-detection module 9 data-port 1 trunk allowed-vlan 2,3,4,22,33,44
!!for fwsm in msfc!!
firewall vlan-group 1 22,33,44
firewall module 8 vlan-group 1
!!IDSM-2 Config!!!!
sensor(config-int-phy)# subinterface-type inline-vlan-pair
sensor(config-int-phy-inl)# subinterface 1
sensor(config-int-phy-inl-sub)# vlan1 2
sensor(config-int-phy-inl-sub)# vlan2 22
sensor(config-int-phy-inl)# subinterface 2
sensor(config-int-phy-inl-sub)# vlan1 3
sensor(config-int-phy-inl-sub)# vlan2 33
sensor(config-int-phy-inl)# subinterface 3
sensor(config-int-phy-inl-sub)# vlan1 4
sensor(config-int-phy-inl-sub)# vlan2 44
blackhat2020 Wed, 12/10/2008 - 00:32
no answer!!please somebody Help!! can i create for example 3 or 6 subinterfcaes for creating 3 or 6 vlan pair on gigabitethernet 0/7??
(how match subinterfcae we can create for example on gigethernet 0/7 in idsm-2)
