pix 501 setup problem
Dec 9th, 2008
our company transfer a new ISP,I have to setup my pix 501 again,
the new IP ADDRESS has 13 static address:
151.XXX.XXX.66 ... 151.XXX.XXX.78 NETMASK 255.255.255.0
GW: 151.XXX.XXX.1
DNS: 68.237.161.12 , 71.250.0.12
i check these ip address one by one, all the address can work,but when i put them to the pix and replace the old ip address, the local pc cannot go to internet, please help me to check it, is there any errror when i setup?
PIX Version 6.3(3)
interface ethernet0 10baset
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list outside_access_in permit icmp any any
ata
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 151.xxx.xxx.66 255.255.255.240
ip address inside 10.0.1.11 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 151.xxx.xxx.68 netmask 255.255.255.240
nat (inside) 1 10.0.1.0 255.255.255.0 0 0
conduit permit esp any any
conduit permit icmp any any
conduit permit udp any eq isakmp any
route outside 0.0.0.0 0.0.0.0 151.xxx.xxx.1 1
timeout xlate 3:<?xml:namespace prefix = st1 />00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 10.0.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt noproxyarp inside
telnet 10.0.1.11 255.255.255.255 inside
telnet 10.0.1.0 255.255.255.0 inside
telnet timeout 15
ssh timeout 5
console timeout 0
dhcpd address 10.0.1.70-10.0.1.101 inside
dhcpd dns 68.237.161.12 71.250.0.12
dhcpd lease 3000
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
Cryptochecksum:44eba47e4c79bf94f39b1bd181bd5df0
: end
vvarakan Tue, 12/09/2008 - 09:54
Subnet mask ?
pdm history enable
arp timeout 14400
itcjohn718 Tue, 12/09/2008 - 13:43
the ISP told me, the netmask is 255.255.255.0
in the pix 501 setup interface, i use 255.255.255.240
is this the problem? if it is the problem, what i should be replace it?
thanks
Jon Marshall Tue, 12/09/2008 - 13:49
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Yes it is the problem because your default-gateway 151.xxx.xxx.1 according to your statement
but the interface address is
so the pix thinks that .1 is in a different network that the outside interface so it cannot use .1 as a default-route. So either
1) your default-gateway of 151.x.x.1 is wrong
OR
2) Change subnet mask on outside interface of 255.255.255.0
Jon
itcjohn718 Tue, 12/09/2008 - 14:10
thanks for your help.
i try to use netmask as: 255.255.255.0
it's not work too.
how i should be to do?
itcjohn718 Tue, 12/09/2008 - 14:17
i test the ip address and gateway, DNS,all of them can working.
when i use netmask as 255.255.255.0
pix not working.
please give me some idea, thanks
