General: NAC Clean Access
Dec 9th, 2008
We are on the process of implementing/testing NAC Appliance. The problem we are having is when the user first time login to the network using CCA, THEY CAN NOT BE ABLE TO MAP TO THEIR NETWORK DRIVES that are part of the script running on windows that map user's home and network drives. The problem seems while CCA is doing its own verification, its blocking user/PC from joining the network and cause mapping not to go through. For now to remedy this, users, they have to re login again once their MAC address is on the certified list they will be able to map their network drives. Again when MAC certification timer expires they are going through the same problem. My question will be is there a way to fix the problem? Please help.
DJ
