Inter-VLAN Routing and existing network
Answered Question
Dec 9th, 2008
Good afternoon!
Maybe you fine folks can help me - Trying to add another subnet to internal network (to eventually transition to this new subnet). Going to use VLAN's for this, but don't know how to create a VLAN and have it route to the existing network for web access, etc. Any suggestions?
(I've got a Catalyst 3560E That i'd like to use to create the VLAN and do the routing between the new subnet and the old)
Thanks!
Correct Answer by Jon Marshall about 8 years 6 months ago
Daniel
First thing that stands out -
"on the 206.97.124.0 side, a machine with the ip 206.97.124.4 w/ a gateway of 206.97.124.1"
I thought you wanted to do inter-vlan routing on the switch ? but you are using a different device 206.97.124.1 as the default-gateway.
If you want to use 206.97.124.1 as the default-gateway for vlan 1 machines then you need to add a route to that device to tell it how to get to the new vlan 2 network ie.
ip route 10.5.0.0 255.255.255.0 206.97.124.28
OR
change the default-gateway on the vlan 1 machine to 206.97.124.28
I'll have a look at files and get back to you if there are other issues.
Jon
Overall Rating: 5 (3 ratings)
Jon Marshall Tue, 12/09/2008 - 10:41
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Daniel
Lets assume you have vlan 1 already on the 3560 with a L3 SVI ie. in the config
interface vlan 1
ip address x.x.x.x
Basic steps to add a new vlan. Assume new vlan is vlan 2 and uses IP subnet of 192.168.5.0/24
1) Create vlan at layer 2
3560(config)# vlan 2
3560(config-vlan)# name v2
2) Create L3 interface for vlan 2
int vlan 2
ip address 192.168.5.1 255.255.255.0
3) enable IP routing on your switch
3560(config)# ip routing
4) vlan 2 L3 interface will not come up until you add at least one port into it or if you have a trunk link on the 3560.
int gi0/10
switchport access vlan 2
the above would add int gi0/10 into vlan 2
5) Any machines you put into vlan 2 must use an address from the 192.168.5.x range and have their default-gateway set to 192.168.5.1
Jon
danielsormsby Tue, 12/09/2008 - 12:12
Jon,
I still can't seem to get it to work. Config is below:
Switch#show run
Building configuration...
Current configuration : 2370 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
no aaa new-model
system mtu routing 1500
ip subnet-zero
ip routing
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
shutdown
interface GigabitEthernet0/1
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface TenGigabitEthernet0/1
interface TenGigabitEthernet0/2
interface Vlan1
ip address 206.97.124.28 255.255.255.0
shutdown
interface Vlan2
ip address 10.5.0.2 255.255.252.0
ip classless
ip route 0.0.0.0 0.0.0.0 206.97.124.1
ip http server
control-plane
line con 0
line vty 5 15
end
Current subnet is 206.97.124.0 255.255.255.0 (I know, don't tell me)
New Subnet is 10.5.0.0 255.255.252.0
I have a connection to the existing network in int0/5 and my desktop in int0/10.
Any suggestions?
Thanks!
Jon Marshall Tue, 12/09/2008 - 12:13
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Daniel
interface Vlan1
shutdown
your vlan 1 interface is shutdown - any reason ?
int vlan 1
no shut
Jon
Jon Marshall Tue, 12/09/2008 - 12:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Daniel
Can you post output of
1) sh ip route
2) sh vlan
3) sh ip int br
which machines/IP addresses are you using to test the connectivity and do these machines have their respective default-gateways set ie.
machine in vlan 1 - 206.97.124.28
machine in vlan 2 - 10.5.0.2
Jon
danielsormsby Tue, 12/09/2008 - 12:36
Jon,
Thanks for all the help!
Various outputs exceeded the limit, they are in a .txt attached.
I'm using the following to test connectivity:
on the 10.5.0.0 Side, a machine with the ip of 10.5.0.3 w/ a gateway of 10.5.0.2
Again, thanks for all the help!
Correct Answer
Jon Marshall Tue, 12/09/2008 - 12:40
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Daniel
OR
Jon
viyuan700 Tue, 12/09/2008 - 12:51
  • Silver, 250 points or more
in 10.5.0.0 daniel is using 255.255.252.0 as mask
Jon Marshall Tue, 12/09/2008 - 12:42
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Daniel
Just checked the file and everything looks okay so i suspect it is the default-gateway issue on vlan 1.
Jon
danielsormsby Tue, 12/09/2008 - 13:53
Jon,
You are the man.
Once I did a ip route from the gateway on the 206.97.124.X subnet, everything worked marvelously.
Thanks again!
viyuan700 Tue, 12/09/2008 - 12:45
"on the 10.5.0.0 Side, a machine with the ip of 10.5.0.3 w/ a gateway of 10.5.0.2 "
hope u r using 255.255.252.0
"on the 206.97.124.0 side, a machine with the ip 206.97.124.4 w/ a gateway of 206.97.124.1 "
Gateway for this should be 206.97.124.28 it is the ip address of ur vlan 1.
CriscoSystems Tue, 12/09/2008 - 12:48
  • Bronze, 100 points or more
Edit:
redundant info deleted - sorrrry
vfrolov77 Wed, 12/10/2008 - 06:24
Hi Jon, your explanations are really useful!
I have a tech. problem with 3750. I have configured vlan1 10.20.20.1 (10.20.20.0/24 net) with fa2/0/2-12, ip routing up. I'm going to have vlan2 10.20.25.1 (net 10.20.25.0/24) with fa2/0/14-20. I'm trying to get them visible with each other (unsuccessfully yet), it means interVLANs routing on the same switch. If I assign IP to the vlan, then they have L3 interfaces and they have fastE. interface assigned and up. I cannot understand where routing interface should be. Can I use gigEthernet for it? Should I assign GE to vlan and what vlan? Switch is VTP server. Apart of that I'm going to use ge2/0/2 as connection to 7200. Can I use one interface for routing purposes? Didn't manage to dig up answers on site yet.
Thanks a lot,
Vlad
Jon Marshall Wed, 12/10/2008 - 06:31
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
Do you want the 3750 to route between your vlans or do you want the 7200 to do it. Ideally i suspect you want the 3750. If so can you post config of both 3750 and 7200 and we can go from there.
Jon
vfrolov77 Wed, 12/10/2008 - 06:36
you are cisco Star. You understand everything =). I'm interested in internal 3750 (two vlans on one switch). I didn't start 7200 yet and 3750 I process, but I'll send config. I'm trying to realise where L3 interface should be for interVLANs.
Thank,
Vlad
Jon Marshall Wed, 12/10/2008 - 06:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Vlad
First have you created vlan 2 at layer 2 ie.
1) run "sh vlan" on the 3750. Do you see entry for vlan 2 as well as vlan 1. If not
3750(config)# vlan 2
3750(config)# name v2
2) Next you need to create routed interfaces for the vlans. On a layer 3 switch you use SVI's (Switched Virtual Interfaces). To create an SVI for vlan 2
3750(config)# int vlan 2
3750(config-if)# ip address 10.20.25.1 255.255.255.0
3750(config-if)# no shut
3) You should already have a L3 SVI for vlan 1. If you but no ip address has been assigned -
3750(config)# int vlan 1
3750(config-if)# ip address 10.20.20.1 255.255.255.0
4) All clients connected to ports in vlan 1 should have an address from 10.20.20.x subnet and their default-gateway should be 10.20.20.1
5) All clients connected to ports in vlan 2 should have an address from 10.20.25.x subnet with default-gateway 10.20.25.1
If you get this working we can then look at your 7200 if you want to add that in later.
Jon
vfrolov77 Wed, 12/10/2008 - 07:02
Great! i will config and let you know, you are genuis.
Vlad
