12-09-2008 10:54 AM - edited 03-10-2019 04:24 AM
Hi all,
looking for some help on a recent upgrade.
We currently have several asa5520 with ssm-10 cards. the ASA's are acting as a transparrent device (vers 8.0.4).
On the ssm-10 vers 6.1.1-E2 we get 1000's of connections shown on the top applications window on the ssm dashboard.
I have upgraded units to 6.1-1-E3 image and the 6.2-1-E3 image on the ssm-10 cards. On these upgrades the top applications window on the dashboard shows significantly reduced connections (from 1500 to 30). I'm happy that the traffic is routing through the ssm units but confused why there is such a big change.
Has anyone else seen this on the E3 upgrades? Your response would be appreiciated.
Many thanks
Ben
12-16-2008 04:16 PM
To install a new system image on the sensor, use ROMMON, the bootloader file, or the maintenance partition depending on which platform you have.
When you install a new system image on your sensor, all accounts are removed and the default cisco account is reset to use the default password cisco. After installing the system image, you must initialize the sensor again.
After you reimage and initialize your sensor, upgrade your sensor with the most recent service pack, signature update, signature engine update, minor update, major update, and recovery partition file.
12-22-2008 03:58 AM
Apologies - I may have been misunderstood...
This question was in respect to an engine update and how the dashboard on the SSM-10 sensor shows stats after the engine update.
We did not require to re-image the devices.
Thansk in advance
Ben.
