External caller hears ring before physical phone rings
Dec 9th, 2008
Have a hunt group set up. When the phone is direct dialed, the caller hears 1-3 rings before the desk phone rings. The desk phone then rings 3 times and, if not answered, the other two phones in the hunt group ring once each. This could cause the caller to hear 8 rings before the call goes to voice mail. How can I shorten/eliminate the rings the caller hears before the physical phone rings?
Overall Rating: 5 (1 ratings)
thomuff Tue, 12/09/2008 - 12:42
Is the DID used in the Hunt Pilot local to the subscriber or publisher. Could a latency across the WAN cause this issue? I would double check my Line group associated to the Hunt group to make sure it is configured properly. What algorithm are you using? Can you change it to a different algorithm?
Bamberger1_2 Thu, 12/11/2008 - 13:55
Thanks for your help. We needed to keep the caller ID but were able to correct this by changing the connection plar to opx immediate.
