Custom Java Class in CRS 3.5(4)
General questions:
My class uses a third party driver (jar files) and I have already modified the CRS server classpath and it works. I can run the class from the command line in the CRS server, do I leave it where it is since I know the server can find the driver? or does it need to be in a particular location?
The admin Guide says that I need to reference it in the customengine.xml file, is this correct?
Can somebody post a sample of this modified file?
Do my custom class have to have any particular minimum requirements such as arguments, constructors, etc.?
In the scripts:
How do I call it from a script?
Do I have to use a variable?
I've read the programming guide and the steps refernece guide and they're not very helpful.
thank you
