Auto answer and Message button
Dec 9th, 2008
Does the messages button get disabled if a auto answer is enabled on the 7941G Phone? or could the message button not work because of maximum number of calls is set to 2 and busy trigger set to 1?
Overall Rating: 4 (1 ratings)
Jaime Valencia Tue, 12/09/2008 - 11:57
no, why would having auto-answer modify the behavior of messages button????
do you have a valid VM profile????
if this helps, please rate
thomuff Tue, 12/09/2008 - 12:05
i have a valid VM profile. I have tested it on my phone. I think it might be the button on the phone. I thought it might have some unique behavior because it is associated to IPCC Express or because the messages button was not picking up.
thomuff Tue, 12/09/2008 - 12:36
it is working now. thanks for your help and quick response.
