12-09-2008 12:26 PM - edited 03-06-2019 02:53 AM
Hi all,
I have an old Cisco 2900XL switch lying around (no idea what is on it) and wanted to use it as a desktop switch. Two questions:
1) If I factory defaulted the switch would this work?
2) Does this switch support auto-mdix?
thanks.
Solved! Go to Solution.
12-09-2008 12:28 PM
1) No idea. Depends if the switch is working anyway. Fctory defaulting won't break anything that isn't already broken so it won't do any harm.
2) No it doesn't.
Jon
12-09-2008 12:28 PM
2) No it doesn't.
Jon
12-09-2008 12:39 PM
Thanks Jon.
12-10-2008 01:39 AM
You will need to delete the old VLAN database in it, to avoid misconfiguration.
DAK
