WAAS - TCP Connection High-Water Mark
Dec 9th, 2008
Is there a way to tell the historical statistic for maximum number of TCP connections in a WAE? We are in the middle of a deployment and I am wondering how well we sized our HQ cluster.
ropethic Tue, 12/09/2008 - 17:08
  • Silver, 250 points or more
Through CM dashboard -> manage devices and go to edge or core device, you will be able to see the connections for each device.
The other option, is to check and see if you are seeing a lot of bypass traffic.
Once WAAS reaches max, traffic will be bypassed until max sessions drops
adamcrabb Tue, 12/09/2008 - 18:23
I don't see what I am looking for there. I would like to know what is the most TCP connections that have been present on the WAE at any one time. I thought I remember someone saying that was a stat you could view but I can't find it anywhere.
