Limiting Bandwidth on a 6509 switchport.
Dec 9th, 2008
We have a user that is gaming, is there a way to rate limit bandwidt to the switchport that is workstation is conncected.
interface FastEthernet7/5
description D40A
no ip address
switchport
switchport access vlan 74
switchport mode access
spanning-tree portfast
oszamora Tue, 12/09/2008 - 17:48
You would need to know exactly the ports that the game uses so you can match them in a class map and then do policing. Here is an example using the class default which includes all traffic since there is not another class
policy-map BW
class class-default
police 2000000 62500 62500 conform-action transmit exceed-action drop
int fa 7/5
service-policy input BW
the policing is set to 2 Mb in this example.
So if you find out the ports the game uses we can permit them in an ACL, then match them in the class map and finally do policing.
oszamora Tue, 12/09/2008 - 17:50
By the way, you could configure SPAN to monitor the port when the user is gaming and discover the ports the game uses
oszamora Tue, 12/09/2008 - 17:55
Instead of policing we can use the option "drop" in the policy map so the game traffic will be droped in the interface. But definitely we need to know the ports the game uses.
