UCCX QM 2.4(1) AD Authentication
Dec 9th, 2008
We have QM 2.4(1) installed and is working okay. However, we wanted to change the authentication settings from QM Authentication to Active Directory Authentication.
I went to the Enterprise Settings on postinstall.exe, however I could not find anything that I can change to enable the AD Authentication.
Is there any way I can change that without uninstalling and reinstalling the application?
Overall Rating: 1 (1 ratings)
jbayuka Mon, 12/15/2008 - 09:18
If you want to integrate your CallManager to Active Directory, you'll have to follow these steps:
1. Configure the LDAP System
System --> LDAP --> LDAP System
Check the Enable Synchronizing from LDAP Server
Choose the LDAP Server Type: Microsoft AD
LDAP Attribute for User ID:
2. Configure LDAP Authentication
System --> LDAP --> LDAP Authentication
Fill in the fields with the correct info to integrate your CM server with your AD
