12-09-2008 11:12 PM - edited 03-15-2019 02:59 PM
Hi Pros,
I am trying to pull raw CDR files from CLI as per the following procedure:
Login to CallManager via SSH:
Username: Administrator
Password: OS Admin password
To view files
- file list activelog *, to view the cdr files, do, file list activelog cm/cdr_repository/destination1/*
To get the files
- file get activelog cm/cdr_repository/destination1/*
When you do the get files command, you will then be prompted for SFTP & username/password
But when I see the directory I can see folders for each date for example 20081112, 20081113, etc.
But these folders are showing up empty.
Now, I want to know 2 things:
1) Have the CDRs been purged ?
2) Do I have the right access ?
admin:file list activelog cm/cdr_repository/*
<dir> car
<dir> destination1
<dir> destination2
<dir> destination3
<dir> preserve
<dir> processed
<dir> tmp
<dir> trans
dir count = 8, file count = 0
admin:file list activelog cm/cdr_repository/destinationa1/*
no such file or directory can be found
admin:
admin:
admin:
admin:file list activelog cm/cdr_repository/destination1/*
<dir> 20081110
<dir> 20081111
<dir> 20081112
<dir> 20081113
<dir> 20081114
<dir> 20081115
<dir> 20081116
<dir> 20081117
<dir> 20081118
<dir> 20081119
<dir> 20081120
<dir> 20081121
<dir> 20081122
<dir> 20081123
<dir> 20081124
<dir> 20081125
<dir> 20081126
<dir> 20081127
<dir> 20081128
<dir> 20081129
<dir> 20081130
<dir> 20081201
<dir> 20081202
<dir> 20081203
<dir> 20081204
<dir> 20081205
<dir> 20081206
<dir> 20081207
<dir> 20081208
<dir> 20081209
<dir> 20081210
<dir> 20081211
dir count = 32, file count = 0
admin:file list activelog cm/cdr_repository/destination1/20081211/*
dir count = 0, file count = 0
admin:
admin:
admin:
Pratik
Solved! Go to Solution.
12-10-2008 09:34 AM
if CDR is inserting the file into DB look at the processed folder instead
java
if this helps, please rate
12-10-2008 09:34 AM
java
12-10-2008 09:48 PM
Thanks javalenc.
So it means if CDR insert is enabled then we shall find the CDRs in 'processed' folder.
Any idea what 'destination1' is for ?
admin:file get activelog cm/cdr_repository/processed/20081113/
Please wait while the system is gathering files info ...done.
Sub-directories were not traversed.
Number of files affected: 205
Total size in Bytes: 580569
Total size in Kbytes: 566.9619
Would you like to proceed [y/n]? y
SFTP server IP: 192.168.107.91
SFTP server port [22]:
User ID: cisco
Password: *****
Download directory: .
Transfer completed.
